Hello,
is it normal that with the NBMiner i have changing hashrates of up to 80mhs.
Sometimes i have 250mhs then i got only 160 and so on everyminute it changes drastically.
Thanks for you help.
Hello,
Your not alone. I have a 3070 running on win 10 with NBminer. I have seen the same variance. Where I go as high as 230mh and as low as 98mh. With an average 24 hr rate of 171mh
I also see the see with an RX 480 4gb. That averages 48mh over a 24hr period but I see where it goes down to 27mh then as high as 80mh.
I sometimes wonder if its not throttling due to heat.
One thing that I noticed helps is to unplug the HDMI cable when not in use…
If anyone has OC settings they can share for the 30 series that would be awesome.
try nanominer. I get 30% more shares. I run at 210 mhs without too much overclocking.
Thanks, I’ll give it a shot.
