Confirmed my Palit RTX 3060 Dual (non-TI, non-OC variant) achieved >120 MH/s mining ERG with these settings:
127,4 MH/s: core -300, mem 2550, pl 130 → 90% fan got 70°C
122,2 MH/s: core -300, mem 2550, pl 110 → 75% fan got 63°C
Using NBMiner on Hive OS, dual mining along with PhoenixMiner mining ETH.
The fan monitor of this Palit 3060 card always stopped at certain minutes after mining any coins in Hive OS, but he fan still running at last % set. To set another fan value, it has to be rebooted.
You have to change you mem timings with Polaris Bios editor. also Elpida mem is usually pretty bad. Try using your 1650 straps up to 1900 or 2000. If 2000 with 1650 straps doesn’t work use the 1750 straps
Maverick,
I have same RX580 4GB with Elpida memory. Is there any chance to download VBIOS from GPU5 and send me to zhoriev*gmail com, please!
I want to check compare with my vBIOS. If u want I’ll return mine to you.
P.S My cards is same model exclude two of them but work different with same bios settings.
The best settings for me is: Core: 1299 DPM: 1 VDD: 885 or 900 MEM: 1950 = 69 Mh 90-91w
This is very true, it is tricky on 3060. From 120 MH/s can be dropped as low as 60 MH/s if the combination is wrong. If I change back to previous settings, it increasing back to previous hashrate. Now I can get 123,2 MH/s with core 240, mem 2400, pl 110. Really have to try and error.
