Please use this topic to share hashrate of your GPU or CPU. Please specify miner and device. Following data is from Discord:
SRBMiner + RX580 7,5 MH/s
SRBMiner + Vega56 16 MH/s
SRBMiner + 5700 26 MH/s
SRB + 5600XT 15.5 MH/s
SRB + Ryzen 3700 1 MH/s
REF Miner + 3060TI 11.5 MH/S
Testnet - No overclocking of below GPU’s (Stock):
NV Miner + 2080 TI - 17MH/s
NV Miner + 2080 Max Q - 10 MH/s (Dedicated Laptop Card)
NV miner + 2060 Super - 9 MH/s
NV miner + 1660 GTX - 5 MH/s
About 30 minutes of mining.
Ref miner (1.0.1) + 1660TI = 5.5 MH/s
Ref miner (1.1.0) + 1665TI + Win + overclock = 17.5 MH/s
Ref miner (1.1.0) + 2070 + linux = 29.5 MH/s
Nanominer 3.2.0 + 1665TI + Win = 44 MH/s
Nanominer 3.2.0 + 2070 + linux = 62 MH/s
NVMiner, 1070 FE, 2 MH/s
gtx1070, NV_miner WIN64 v1.1.0, 14MH/s
NV Miner (1.1.0) - 1080 - ~19 MH/s (17.8 < 18.9 > 19.2)
Testnet - No overclocking of below GPU’s (Stock): 1.0.0 NV miner
–Old hashrates–
Mainnet - No Overclocking of below GPU’s (Stock): 1.1.0
Hashrates improved with new release.
NV Miner + 2080 TI - 17MH/s>>>42MH/s — 240% increase better hash
NV Miner + 2080 Max Q - 10 MH/s>>>27MH/s — 270% (Dedicated Laptop Card)
NV miner + 2060 Super - 9 MH/s>>>35MH/s — 388%
NV miner + 1660 GTX - 5 MH/s>>>15MH/s — 300%
About 15 minutes of mining.
SRBMiner-MULTI + 5700 xt → 23 MH/s
1070 NV miner V2 : 27Mh/s
1070 nanominer : 47 Mh/s
Nanominer + 1060 6 gb - 36 Mh/s
RX 470 = maximum 30 M/hash , SRB , auto GPU overclock done inside AMD Radeon Software
Hive 1063 nanominer v.3.2.0 (core 100, mem 1650) - 38,5mh
Hive 584 srbminer v.0.6.6 (core 1250, VDD 950, mem 2200) - 63,5mh
Hello everyone.
I want to mine ergo, but there is something wrong with srbminer, sometimes it kind of stops/freezes, and gpu’s stop working but after a while is starts again. I tried to find some information about gpu clocks to use, but unsuccesfuly. I have sapphire nitro plus rx 480 8gb cards. What clocks you guys using for your gpu’s? thanks in advance.
Nanominer 3.2.2 w/ RTX 3070 - 142MH/s
Nanominer 3.2.2 w/ RTX 3070 FE - 171 MH/s
-400MHz Core, +1300MHz RAM, 60% Power for 120W
Nanominer
W/ RTX 3090 FE 275 MH/s
-76 Power, +225 Core, +1460 Mem, 255W (Power is free)
W/ RTX 2060 60 MH/s
+220 Core, +1400 Mem, 89W (Laptop)
Rx 580 8g=71mh 109w 2100mclk
Rx 460 4g=29 23w 1800mclk
NanoMiner for all
RTX 3070- 174 MH 124w (+1300mem -200 core -52% power)
RTX 2080TI- 115MH 180W (+1200mem -575 core -70% power)
GTX1080- 48mh 120w
GTX 1060 6gb- 45mh 70w
GTX 1050ti 4gb- 25mh 60w
Nanominer 3.2.2 + RX 570 45 MH/s (used while not using the PC, as DAG generation causes massive lagspikes)
SRBMiner 0.6.7 + RX 570 43 MH/s (used while actively using the PC)
Specific GPU is the Sapphire Pulse RX 570 4GB.
This is with the core clock set to 850 MHz, core voltage set to 0.750 V, and memory clock set to 2000 MHz with auto voltage. GPU power is around 60 W, and total system power consumption with the CPU also underclocked and mining another coin (QRL) is ~175 W. Hashrates at my preferred gaming overclock are around 48-50 MH/s. IMO the extra heat generated and power used are not worth the extra hashrate.
