can you share your bios for R9_380? my email: hiepntkiotec@gmail.com
Here You can find all informations needed: Nerd Ralph: Advanced Tonga BIOS editing
Hey! How are you able to get stable 108MH/s on the 3060 in HiveOS? Mine starts at around that but drops to around 60MH/s in a few minutes… Thanks!
Hey! How are you able to get these hash rates on HiveOS? Mine starts at around 100 but then drops to about 60 in a few minutes… Thanks!
well the settings are as shown above… running at 120-125MH for weeks now! Not sure what the problem is with your card dropping the hashrate. What settings are you using?
I’m getting about 67-68MH/s on RX 570 with tighter timings at 1295 core 1950 mem 92w.
With an old R9 290x I’m getting 57-58MH/s at 1075 core 1250 mem.
Are you using nanominer v.3.3.4-cuda111?
nanominer: v3.3.3-cuda111
which nvidia driver are you using? I had trouble with newer drivers, but the best version for me is: 455.45.01
HiveOs let’s you install this on the command line
hi, any one tell me how much dag size of Ergo or Autolykos2 ? I have try to mining with GTX1050-2G but it can not. I can’t find size of dag.
Thanks for the infos! It appears to be more stable now at 104.5mh/s, don’t really know why. Will try your driver and settings!
Hi there, I have 2 rigs with 6x XFX rx570 (4gb, elpida mem)…
Highest stable hashrate I got is 51 MH (1150 core, 1800 memory).
Everything past 1800, I get a lot of rejected shares… Is that normal? bc I saw some of you guys get 65+ MH with the same cards
Any help? Thanks :grin:
Any help? Thanks
I replaced motherboard and PSU (from ATX to server PSU). Now it’s … 735W (ATW)!
SRBMiner, 6 x R9_380 + CPU mining activated = 271MH/s and 735W (ATW)
SRBMiner, 6 x R9_380 + CPU mining deactivated = 271MH/s and 685W (ATW)
Nanominer
Sapphire RX580 8gb1200/2250 = ~54mh/s
MSI RX570 4gb 1150/2000 l2 timings= ~56mh/s
Both slightly undervolted so I dont have crazy fan noise since they’re in my normal PC. The l2 timings have a HUGE positive effect. The problem is even at stock the 580 (samsung memory) wont take the l2 timings without crashing. It’ll take full OC on the memory though so thats where I’m at…
XFX RX 580 Black edition oc+ 8gb
Nanominer - Latest update
Avg - 66 MH/s @ 85w
No Errors, no issues yet… will update after 3 hours
see image for proof.
Gigabyte RX 570 Gaming 4GB
Avg - 62.7 MH/s @ Avg - 78W
HIVEOS:
Core Clock 1167
Core Voltage 925
Memory Clock 2000
Advanced config: amdmemtweak --REF 20
Hello guys.
My 1st rig is 8 x rx570 4gb
My 4th rig is 1 x rx570 4gb samsung memory; 4 x rx580 4gb; 1 x rx570 4gb
I have a Second and Third Rigs. They are with 6 x nitro+ rx580 4gb, which are the same as the ones from my 4th Rig.
This is my 1st time mining and i have been mining from 1 month now.
1st rig has 1150W at the wall. PSUs are not the best.
2nd rig is 820W at the wall
3rd rig is 820W at the wall
4th rig is 820w at the wall
I have an EVGA 1200w and I plan on putting it on the 8 GPU rig sometime soon to see if I will lower the watts.
