Hello, is there a source of reference I can use for the steps to transfer assets from one Yoroi Trezor wallet to another.
Thank you for any information.
Hello, this would be an ergo forum. I believe your probably looking for the ada forum. Either way, yoroi doesn’t hold your assets, the blockchain does. Yoroi just allows you to interact with the blockchain easier.
You just send your assets to the another wallet address and I guess sign the transactions using your trezor (havnt used trezor, assuming its the same as ledger).
Makes sense. Thank you. Still learning. Appreciate the feedback.
no worries at all. Feel free to check out any of the other forum posts here or ask any other questions
