Recently a new version of the ERG-USD Oracle-Pool was launched. The only difference from the earlier one is that this version has an updatable contract.
What is an Updatable Contract?
Recall that Ergo has the concept of “contractual money”, which implies to Ergs (primary assets) and tokens (secondary assets) on the Ergo blockchain. Contractual money is essentially assets locked in
contracts that restrict their free flow. Such contracts require that the assets be spent only in certain ways and can only be stored in boxes protected by certain contracts and containing certain data in their registers. One such example of contractual money is the oracle-pool box. An oracle-pool box contains a token that can only be stored in either a “live epoch box” or a “epoch preparation box” with additional conditions on the register values.
Such contracts make the system trustless. However, they also make it inflexible. For instance, if we want to change the oracle pool to allow higher deviation percent in the submitted rates, we cannot do it because the max deviation is hardcoded into the contract.
An updatable contract is one that can be updated based on some predefined voting mechanism.
In order to change contract parameters, sufficient votes agreeing to the change must be cast.
Update Requirements
We define the following requirements of our oracle-pool contract:
- Update the script (address) of the epoch-preparation box
- Preserve the registers of the bank box
- Preserve the tokens of the bank box
Voting Mechanism
In order to allow an update, we will require at least a certain minimum threshold number of holders of a certain token (the “ballot” token) to agree to the new script. Currently we have the following parameters.
- Total number of ballot tokens: 12
- Threshold for successful vote: 6
To cast a vote, each token holder just needs to compute the hash of (the ergo-tree of) the new address and store that value in R4 of a box along with a ballot token at the first index.
Update Contract
The voting and update mechanism is managed by another box, called the update box. This box also hardwires the voting parameters mentioned above and is protected by the update contract. In particular this contract has the following actions (spending paths)
- Collect votes: To finalize the new oracle pool epoch preparation box script via the hash stored in R4 of the ballot boxes. This preserves everything in the update box except R4, which will contain the hash of the new oracle-pool box.
- Update: to perform the actual update of the oracle-pool (epoch preparation) box address while preserving its tokens and registers, and preserving everything in the update box
This update box is uniquely identified by a singleton token, the update NFT.
Oracle-Pool Contract
The update will happen in the epoch preparation box, whose contract remains the same as before with
an additional spending path pertaining the the update action above. This is encoded as
originalPath || <second input contains the update NFT>
The alternate spending path enforces no additional conditions apart from the requirement that the second input contains the update NFT. The various update constraints (such as preserving the registers
and tokens) are enforced by the update contract instead.
Actual Contracts
The following are the actual contracts taken from here
Only epoch preparation and update contracts given, since these are the only contracts affected by this change
Epoch Preparation Contract
// This box:
// R4: The finalized data point from collection
// R5: Height the epoch will end
val canStartEpoch = HEIGHT > SELF.R5[Int].get - $livePeriod
val epochNotOver = HEIGHT < SELF.R5[Int].get
val epochOver = HEIGHT >= SELF.R5[Int].get
val enoughFunds = SELF.value >= $minPoolBoxValue
val maxNewEpochHeight = HEIGHT + $epochPeriod + $buffer
val minNewEpochHeight = HEIGHT + $epochPeriod
val poolAction = if (OUTPUTS(0).R6[Coll[Byte]].isDefined) {
val isliveEpochOutput = OUTPUTS(0).R6[Coll[Byte]].get == blake2b256(SELF.propositionBytes) &&
blake2b256(OUTPUTS(0).propositionBytes) == liveEpochScriptHash
( // start next epoch
epochNotOver && canStartEpoch && enoughFunds &&
OUTPUTS(0).R4[Long].get == SELF.R4[Long].get &&
OUTPUTS(0).R5[Int].get == SELF.R5[Int].get &&
OUTPUTS(0).tokens == SELF.tokens &&
OUTPUTS(0).value >= SELF.value &&
isliveEpochOutput
) || ( // create new epoch
epochOver &&
enoughFunds &&
OUTPUTS(0).R5[Int].get >= minNewEpochHeight &&
OUTPUTS(0).R5[Int].get <= maxNewEpochHeight &&
isliveEpochOutput
} else {
( // collect funds
OUTPUTS(0).propositionBytes == SELF.propositionBytes &&
OUTPUTS(0).value > SELF.value
val updateAction = INPUTS(1).tokens(0)._1 == updateNFT && CONTEXT.dataInputs.size == 0
sigmaProp(poolAction || updateAction)
Update contract
{ // This box:
// R4 the "control value" (such as the hash of a script of some other box)
// ballot boxes (data Inputs)
// R4 the new control value
// R5 the box id of this box
val isUpdate = INPUTS(0).tokens(0)._1 == poolNFT
val updateBoxIn = if (isUpdate) INPUTS(1) else INPUTS(0)
val updateBoxOut = if (isUpdate) OUTPUTS(1) else OUTPUTS(0)
val validIn = SELF.id == updateBoxIn.id
val voteSuccessPath = {
val newValue = updateBoxOut.R4[Coll[Byte]].get
val oldValue = updateBoxIn.R4[Coll[Byte]].get
val validOut = updateBoxOut.propositionBytes == updateBoxIn.propositionBytes &&
updateBoxOut.value >= $minStorageRent &&
updateBoxOut.tokens == updateBoxIn.tokens &&
newValue != oldValue
def validBallotSubmissionBox(b:Box) = b.tokens(0)._1 == ballotTokenId &&
b.R4[Coll[Byte]].get == newValue && // ensure that vote is for the newValue
b.R5[Coll[Byte]].get == SELF.id // ensure that vote counts only once
val ballots = CONTEXT.dataInputs.filter(validBallotSubmissionBox)
val ballotCount = ballots.fold(0L, { (accum: Long, box: Box) => accum + box.tokens(0)._2 })
val voteAccepted = ballotCount >= $minVotes
validOut && voteAccepted
val updatePath = {
val epochPrepBoxIn = INPUTS(0)
val epochPrepBoxOut = OUTPUTS(0)
val storedNewHash = SELF.R4[Coll[Byte]].get
val epochPrepBoxOutHash = blake2b256(epochPrepBoxOut.propositionBytes)
val validPoolBox = epochPrepBoxIn.tokens(0)._1 == poolNFT && // epochPrep box is first input
epochPrepBoxIn.tokens == epochPrepBoxOut.tokens &&
storedNewHash == epochPrepBoxOutHash &&
epochPrepBoxIn.propositionBytes != epochPrepBoxOut.propositionBytes &&
epochPrepBoxIn.R4[Long].get == epochPrepBoxOut.R4[Long].get &&
epochPrepBoxIn.R5[Int].get == epochPrepBoxOut.R5[Int].get &&
epochPrepBoxIn.value == epochPrepBoxOut.value
val validUpdateBox = updateBoxIn.R4[Coll[Byte]].get == updateBoxOut.R4[Coll[Byte]].get &&
updateBoxIn.propositionBytes == updateBoxOut.propositionBytes &&
updateBoxIn.tokens == updateBoxOut.tokens &&
updateBoxIn.value == updateBoxOut.value
validPoolBox &&
validUpdateBox
sigmaProp(
validIn && (
voteSuccessPath ||
updatePath
Tests
Please refer to the following tests for the update mechanism
- Voting spec for testing the voting mechanism
- Update spec for testing the update mechanism
