Hi, I’m using 1060 6GB - Vram Samsung with HiveOS. I see some other setting for this card with contain the character “–mt6” with high efficiency on hashrate.
Could someone help me to find it? Here’s my overclocking setting
Thanks!
Thanks!
You have to setup it in your miner extra config arguments. In my case NBMiner has the best performance.
Thank you for your reply, I found the extra config with NBminer. It’s easy to add than the other miners.
