RTX 4060 TI 16 GB Overclock Settings Question
Hi All,
I did not know where to add this question in the category
I have RTX 4060 ti 16GB on my Rig.
can anyone help me to give me the correct Overclock settings?
I am able to mine at 172 MH for both GPUs.
I am able to get very low number of coins.
My current settings are as follow:
Lock Core Clock = 1500
Memory Clock Offset = 3300
Power Limit = 135
I am using herominer with lolMiner with extra comments as below:
–cclk 1500 --moff 3300 --pl 135
can you please help me get better MH rate?
waiting to hear back.
Welcome fellow miner. Do not go to the link from the person that commented below you. Ergo support is available via the support channel on Telegram, in the public group.
Ignore all DMs, do not listen to scammers that promise special support. They are not from Ergo.
Here is Ergo telegram: Telegram: Contact @ergoplatform
Support channel is there, but below is the mining channel.
Here is the mining discussion: Telegram: Contact @ergo_mining
Sir, you do not represent Ergo, please take scams elsewhere.
Thank you Grayman for saving me from Scammers.
Hi GrayMan, this is Harpal again, I try to join the group, but seems like they ignored me, can you please help me to join the group please?
I am not able to ask any question or dicussion there, Please accept me for approval.
Acknowledged.
Working on it…
You good? You there?
