Ergo is not available on Hotbit, does anyone else like that or do you know what happened?
its happening on various coins at hotbit, their telegram is full of complaints. you likely need to wait for them to fix whatever they have wrong. the funds should be unlocked and then remove the funds asap.
If it continues you can try contacting hotbit support like after others are not reporting issues in telegram for example but you still are.
Otherwise it has happened a couple times that hotbit has had issues which results in coins locked after attempting to withdrawl…
Currently coinex is free of issues and has a lower withdrawl fee than hotbit 2 erg and coinex 0.1 erg.
Goodluck and patience.
