tERGminal
I have finished the pocket Swiss army knife. It is written in python and tested on a MAC, Raspberry Pi 4 and Raspberry Pi Zero w. Its code is Open SourceInfinite thanks to the ergpy repository.
Requirements
Java 8 or higher
pip install JPype1
pip install ergpy
Usage
python ergpyMenu.py
Once configured with your seed phrase, you can perform the following operations:
whiteList.py
The whiteList file includes an array in which the wallet addresses for options 2 and 5 can be included.
colorsPython.py
Is for the graphic part on the screen.
Remember that this is a **non-audit application,** although I want you to have no problems with your ERGs, I recommend that the seed phrase you enter (it will never be stored) corresponds to a wallet that is not your main wallet.
The seed phrase is not stored anywhere, it needs to be entered every time the dapp is run
For the options that display information (9, 10 and 11) there is no need to configure the wallet.
tERGminal in action
In this tweet you can see tERGminal in action sending NFT to a random wallet.If you try to use tERGminal and don’t succeed easily because you don’t have experience with python or Raspberry Pi, feel free to ask me any questions you need.
Any suggestions are welcome.
