Having issues with my node wallet I think. I have a local node and a stratum server. Set up to mine to it. Looks like I hit a block showing a mining reward but my mobile wallet that should be the same address shows 0 and so does explorer. If I try to transfer funds I get the following error.
Not sure whats going on. I tried a wallet rescan. Funds showed up again but still not on anything else.
Update
Had to fix .conf file. Added check eip argument to node config. Rescan wallet from before the block then send a transfer to myself. Was unable to send the full amount but as soon as I sent a chunk it all populated.
