Hello guys,
I have issue with correct settings for nanopool password for modify Payout limit.
By default payout is 5 ERG, but have settings in pool.
I try different settings in nanopool miner. Contact support. Re-create rig and much more but every time when I try to modify amount, pool say Incorrect password. Like I sayd when I make new setup of miner. Re-create rig.conf.
Please if any from you have correct order to make HiveOS+Nanopool miner in nanopool to work cirrect with password (in case mail), say please?
I am having the same problem, I tried to change the email address by code “email = 123@email.com” “email= %123@email.com%” , the pool still keep saying incorrect password. anyone know how to config this?
Thank you
I’ll try and need two or three days to give feedback. This 2 or 3 daya is needed time for removing old offline rig from nanopool (automatically).
If not create new rig and just input options, settings not run again. This is advice from nanopool support.
