- #1182 : Dockerfile: configurable java heap
- wallet/boxes fix. This API method now correctly return all the wallet boxes, spent or not.
- wallet scan has been reworked to have improved efficiency and memory footprint
Migration from 3.2.x:
If you're running 3.2.x node, just remove wallet/registry subfolder in your ergo data folder (e.g. ~/.ergo). Unlock the wallet after running the node (you can lock it a minute later).
