This release is introducing new API methods:
- /blocks/chainSlice to get headers in a specified range
- /utxo/byId to get box by an id (if the node is holding UTXO set, e.g. working in “utxo” mode)
- /utxo/byIdBinary to get hex-encoded box bytes by an id (if the node is holding UTXO set, e.g. working in “utxo” mode)
- /utxo/genesis to get genesis state of the blockchain (before the genesis block)
Also, optimizations made in 3.0.2 made “height” field in /wallet/balances showing height of a last block affecting the wallet. This behavior has been reverted, so the “height” field shows current height now.
No database reset is needed!
