Hello,
It seems like one of the biggest challenges in blockchain development is handling integrations efficiently. For developers working with the Ergo blockchain, interacting with a node often requires dealing with APIs, syncing data, and managing connections manually.
I just came across Nango and it looks like it is designed to simplify API integrations by handling authentication, syncing, and data retrieval in a more streamlined way. Instead of writing custom code for every interaction, developers can focus on building applications while Nango takes care of the heavy lifting.
Am I wrong to think something alike this could help Ergo developers?
- Easier Node Interaction – Instead of manually handling API calls to an Ergo node, Nango could act as a bridge, making it simpler to fetch and process blockchain data.
- Lower Barrier to Entry – New developers could start working with the Ergo blockchain faster without diving deep into node management.
- More Efficient Development – Teams could focus on building dApps, wallets, or analytics tools without worrying about maintaining complex integration logic.
Would this kind of solution be useful for Ergo developers?
Has anyone tried using API Integration tools like Nango with an Ergo node, and do you see potential benefits in something like making node interactions easier?
Example Use Case:
Let’s say you’re running a local Ergo node and want to build a tool that lets users check their Ergo wallet balances without dealing with raw node requests.
Traditional way:
- Directly query the node’s
/wallet/balanceAPI. - Handle authentication manually.
- Deal with parsing and errors yourself.
With Nango:
- Set up a pre-configured API integration that fetches the balance.
- Nango handles auth + request management.
- You get clean, structured data without writing extra logic.
Who This Helps
- DApp devs who want to fetch data from Ergo nodes without writing complex API handlers.
- Miners/node operators who need to expose limited API access in a secure way.
- Traders/analysts who want to sync Ergo data with external platforms or databases.
Looking forward to everyone thoughts.
Thanks,
Fitz
