Q&A on mining (for pool operators and solo miners)
This Q&A is for pool operators and solo miners mostly.
Why are mining rewards going to some strange addresses?
Mining rewards are going to UTXOs associated with special scripts which are locking rewards to miner public keys for 720 blocks (72 in the testnet). Examples of such scripts are mPdcmQkPPvyJZtvwyc2ZFboEue1X1uMw729UbUhe5ZoQJAQsWyKmLckLx9bRX1YU33uJTq5mCdGdG6Sb (testnet), 88dhgzEuTXaQ3tvkG8KeHesmXdvVomxHoHK5ExawGuxhs3nwBKkoQTxZogna6Dx9Jbu7KG2Wor22Uy73 (mainnet).
Such UTXOs do not belong to the node wallet before the locking height, thus wallet does not include them into balance. However, such UTXOs are stored in a special node application with id = 9 (wallet application id = 10), thus they can be found via /scan/unspentBoxes/9 (so /scan/unspentBoxes node API method with id = 9).
After enough confirmations (720 for the mainnet, 72 for the testnet) wallet shows mined rewards even if they still associated with long scripts, not short P2PK addresses.
How to find if some block is mine?
Before enough confirmations (720 for the mainnet, 72 for the testnet), you can find reward UTXOs with /scan/unspentBoxes/9 API call, after that you can find rewards in the wallet.
Also, you can get mining rewards with /mining/rewardAddress API call, getting something like:
“rewardAddress”: “mPdcmQkPPvyMGoCDNg9oiasLyPpKJhHjgjpt89uJZE1oN9PJ9fKbdKDcfomtWoy3d1E7RFLTUbXbt1AS”
as result. Then you can check rewards with e.g. explorer as Ergo Explorer .
Also, you can get “raw” public key of miner via /mining/rewardPublicKey, getting something like>
“rewardPubkey”: “03aa53abda9e6c958ed6046e6092b901662a26a01a2029c417b1c3f29b4b1c2799”
And then check block headers (“pk” field) for this public key.
