I have one 3060 TI LHR Palit OC and having 130-132 MHs on NBminer.
Clock -200, Mem +950 at 119 W.
It seems that some LHR affects also ergo mining. You can check the hash diferences between the 3060 and the 2060 TI at the whattomine website.
Hi, did you find any way to overcome this problem? If I try to OC the MSI 3060 ti LHR, card is just reseting.
Asus 3060 ti dual OC v2 LHR / Hynix Memory.
Got stable 130 but now experimenting a little. I hope for 140Mh/s.
Something wrong about LHR cards. I had MSi RTX 3060 Ti Gaming X LHR (Dual Fan) with Hynix memory. It was stable 131 mh/s 116w but now I got Galax RTX 3070 LHR 1 click oc. Its worse than msi rtx 3060 ti gaming x. It stuck 91 mh/s even with Samsung memory. I guess lhr cards have limit on any kind mining.
I have PNY which seems that have the same bios, try this on Linux, Core Clock 1060, Memory Clock 2600, PL 130, you should get around 120 Mhs
Has anyone experienced 90mh stuck on Gigabyte GeForce RTX 3060 Ti GAMING OC PRO 8GB V3 LHR Graphics Card? Just ordered from Amazon and I have some doubt about V3 cards as noticed some comments like also Ergo is limited to 90mh on V3 cards.
also, I think you are right.
i have the same problem, OC is setting, but just 90mH.
Hey mate I do have a 3060 TI LHR PNY that gave me a bit of headache but I got stable at 130.1 the OC settings for Hive is Absolute core clock at 1310 memory at 1920 PL 140 (about 110 W ) and 80 % fan (50/53 temp) =) quite solid OC and it is working for 2 days without any reject . Luck there mate =) cheers
You have Hynix memories, I have Samsung
I picked up a Gigabyte Eagle OC 3060 ti LHR V2 (Samsung DDR6) yesterday and it’s definitely super-nerfed for mining ERG. Can’t get over 90mhs on any OC settings. Weirdly, I switched to RVN and it’s pulling 29mhs no problems so I will stick to that. Also was able to get 43mhs on ETH using NBminer.
There is no problem unlock lhr cards to get 42-43 mh/s for eth. Many 3060ti/3070 lhr cards stuck 90-91 mh/s for ergo.
It seems LHR may have influence on mining EHT (ca -50%) and ERGO (ca -25%).
Ravencoin and VTC can be mininig without loss.
Gigabyte v2 version?
I have a similar problem. I have 12x Gigabyte GeForce RTX 3060Ti Gaming OC LHR (GV-N306TGAMINGOC-8GD 2.0). Performance drops to 85-90 Mh / s but not on all cards! All cards are the same version of REV 2.0. Every time after restarting and changing ports, the same cards keep the same performance.
Yes, REV 2.0, GV-N306TEAGLE-8GB
With your settings my Palit went down from 135 Mh/s to 75. So not sure if there params are the best.
I have gigabyte 3060ti v2.0 eagle and has problems with ergo, it’s oscilating from 70-107 mhs, crap, fortunately i can return it, does anyone have experience with msi 3060ti ventus v2.0?
Try to use ambrozy clocks:
core: -625 mem: 2700 PL: 110
