Greetings
GPU 0 RX570 4G Mini Sapphire
GPU1 RX570 4G Power Color
i think this is the best for hashrate vs power consumption
the next battel is lower the GPU temp, is a big challenge mining at summer especially around 12-1pm
can you share your new setting please ?
I’m using Asrock RX570, I dont really know why i cant get that low power consumption, and I dont really understand how to use overridentools
is same mod bios you share https://youtu.be/fPMSMF30fvg i also use same step. more detail you can see the right window all my memory n core setting show detail.
different brand give different result, i have 2 brand both give different result event both have same samsung memory, rx 570 mini with 1 fan use more power than 2 fan, but 1 fan more cooler than 2 fan.
and i don’t know why n how to explain.
if u can get around 69- 71mhs with 93watt is nice.
I’m pretty happy now with my hashrate thanks to you for sharing your OC setting, I will try to tweak it a lil bit more later, lets see the result
This is the settings I have, I only have 1 Vega 64 right now. Averaging 190mh-210mh.
Any tips or extra settings? Am I too high on anything?
I’ve been tweaking it about every hour, trying to find the best settings, any suggestions would be great?
I’m not too tech savvy, just a heads up.
I have three RTX 3060 (non-Ti). I can apply the following settings to boost it up to around 110 MHs.
The result
Could anyone share the settings, miner and mining pool for RX 6900 XT? First time looking for Ergo mining and i’m a bit lost.
Thanks!
I´m with MSI rx 570 4GB samsung memory , mining with team red miner:
clock 1275
voltage: 900
memory clock : 2100
mem voltaje: 925
mem sincronization: timming 2 (read that from this forum and improved mi mh/s)
power consumption: 88w
temp: 62-64° with 34% fan
all these config from amd radeon adrenalin
My mh/s is 51, the average that team red miner says.
How can i improve? Thanks
hi can i know your asrok rx 570 memory brand? is samsung or elpida?
thanks before
Hello , you open your raedon software and go to manual tuning , try keeping this settings for your card and try to find correct clock speed
kkeep vram tuning around 2050 to 2060
my 2*3060 around 101-102 MH/s… I couldn’t get above it
