Sorry for the late reply.
In Hive OS, nanopool, nanominer,
ASUS ROG STRIX 3070TI gets me only 159.7 MH/s with 1200 Core, 2600 Memory, 185 Power Limit, but it’s using only about 139 Watt.
What should be the optimal OC settings, and what should be the stable hash rate?
thank you for overclock! what is your driver version?
NBminer Driver 460.39
unlocked my voltage for all my cards except the zotac
+300mhz for memory instead of default 0 like the last time i posted.
these are all non LHR, my friend is using HiveOS and having trouble matching the hashrate.
anyone know how to match MSI afterburner settings to HiveOS?
i’m using driver 461.92
vvvv this HWinfo on one of the 3070s vvvvvv how do i match that to HiveOS?
Could someone recommend a tutorial on how to match memory OC for specific GPU?
I’ve seen once someone mentioned in some chat (I think it wasn’t in this chat), that if they knew what is the exact memory type or clock, then they would be able to determine exact memory OC. Maybe it was for Core (I simply can’t remember exactly, it’s been some time ago). Any good technical document, blog, or literally any help would be a major help.
I get consumtion 60 watt at 76.6 mh/s with you setting set mem 1400
Sharing an AMD rig I also mine ETH with. It’s easier to power starve NVIDIA cards on this Autokylos algo. I enjoy mining Ergo much more. I live in the desert.
I won the shuffle and picked up a gigabyte 3060ti LHR V2, I’m happy getting 80% of non LHR cards for hashrate
Anyone tried nbminer 39.5 with lhr settings for 3060ti?
In HiveOS try with driver 460.39, it works good with 3060, I’m not sure how the driver will respond to lhr 3060ti… Let us know how did it go.
So I’m mining eth right now, overclocks set for it. Usually, RTX3080 is 225mh, RTX3070 is 171mh RTX3060 about 120mh. I’m building a 7gpu RTX3060, people really selling them cheap here in Sweden.
how much price cheap 3070 in sweden?
my settings from earlier applied to an old used sapphire vega 56… 151.7mh at only 84 watts! really awesome!
Hi,
I’m running this rig full Ergo, low cost and low power consumption, you want me to fill your xls file with my hashrate ?
It runs only BIOS modded AMD cards (PolarisBiosEditor1.7.5)
Hi Guys this my 60minutes test on My Zotac 1060 3GB mini
Nb Miner 39.5
NV Driver 471.96
Forcing P2 State Off
OC seting -
Core -100
Mem +600
Pow Limit 60%
*Note, Iam using custom 120mm Fan with no PWM controler, because my original GPU fan was broken
I got stable at
58.2MH
with 71Watt
61-62 Temp
Thanks
