it is 3080 Ti
Core - 100
Memory +950
PL 200W
If you give me the card serial number I can help you with the timings, because there are two types of hunix memory
was it stable? if yes then try to tune it up.
Gainward GTX 1070 Phoenix GS
Windows 10 - NBminer
77.3 MH/s
Core +0
Mem +750
Power Limit 47%
Power 79W
Fan 30%
Temp : around 53°C
Gainward RTX 3060 TI Ghost V1 (LHR)
Windows 10 - T-Rex miner
around 134 MH/s (136 if ambiant temp low, still have to experiment around this)
Core -460
Mem +1350
Power Limit 51%
Power 101W
Fan 35%
Temp : 60°C
LHR kicks in at 900 MHz core clock
GALAX RTX 3060 TI 1-Click OC LHR - Hynix
HiveOS - NanoMiner
Around 132-134 MH/s
Core 300
Mem +2150
Power Limit 121W
Fan 70%
Temp : 54°C
Hello there.
I have the following numbers on my card
amdmemtweak –RC 35 –RP 13 –RAS 22 –REF 65500 –RFC 148 –RRDL 4 –RRDS 4 –RCDRD 22 –RCDWR 4
I can’t go further than that, it keeps falling.
Rave OC
1070ti core 0 mem +1600 pl 90. 1070 core -50 mem +1150 ( samsung) +1050( micron) pl 90. --mt 6
RTX 3060 Ti 8GB Samsung Memory
Gigabyte Eagle OC V2 LHR
Hiveos Nanominer - Nicehash pool
90mhs
Core - 500
Mem 2500
PL 130W
Temp 52C
My two Hive OS rigs, RX570/RX470, had to setup two rigs, ASUS MB only supports 4 gpu’s
I also have one rig running in Win 10, the RX570 will not run in Linux, runs fine in win environment.
try…
Core 300
Mem +2150
Power Limit 121W
Fan 70%
Im using HiveOS and prefere Absolute Core Lock settings because power and temperatures, At this moment hashrate is the same for core 800-1000 and memory 2000-2200. For core more than 1000 hashrate going down
Hello.
Can you please share the OC?
Thanks
go with memory 2600 and tell us your hashate
RX470 4Gb 39.93mh/s
GTX1060 6Gb 38.05mh/s
are these numbers good for those cards?
RX 470 should be in the 58-62mh/s easy
Try core at 1150 and mem at 1950, you can see my settings a few posts up
Three cards currently mining ERGO. NOTE! All three cards are water-cooled, 3090 with an active backplate.
Miner: T-Rex 0.21.6
OS: Windows 10 Pro 64-bit
Card1: Strix 3090 OC
- Core locked at 1395MHz @ 750mV
- Memory clocks +1500MHz
- Power limit 68%
- Hashrate: 260-265MH/s
- Core temp: 39-43C
- VRAM temp: 58-64C
Card2: Strix 2080Ti
- Core locked at 1350MHz @ 706mV
- Memory clocks: +1250MHz
- Power limit: 53%
- Hashrate: 121MH/s
- Core temp: 39-41C
- Hot spot temp: 52-56C
Card3: Strix 2080Ti
- Core locked at 1350MHz @ 725mV
- Power limit: 53%
- Hashrate: 121MH/s
- Core temp: 39-41C
