Currently ErgoTree (and ErgoScript) programs are interpreted in a “not-so-lazy-way” to ensure fail-safe cost evaluation and prevent some attacks in the AOTC model. This could change in future if JITC is used. This issue is also referenced here and here.
Due to this, certain programs with branches may not execute as intended. For instance, if one branch requires a register to be of type Long and another branch requires it to be of type Coll[Byte], then one branch may become unspendable. As an example the following code has the issue:
sigmaProp{
val condition = OUTPUTS(0).R4[Int].get == 1
val data = CONTEXT.dataInputs(0)
if (condition) { // assume data.R4 has Long type
data.R4[Long].get <= SELF.value
} else { // assume data.R4 has Coll[Byte] type
data.R4[Coll[Byte]].get != SELF.propositionBytes
If condition is true, the AOT coster will still try to read data.R4 as Coll[Byte] even if that branch is not going to be executed. Consequently, no matter what we do, the execution in the true branch will always fail.
There are two approaches to get around this:
1. Use different registers
sigmaProp{
} else { // assume data.R5 has Coll[Byte] type (different register)
data.R5[Coll[Byte]].get != SELF.propositionBytes
In the above approach, irrespective of the branch, we would need to have both registers of data populated with values of the correct types, even though we use only one. In most approaches this should be sufficient. However, if the contract is complex with multiple branches or if there is a dearth of registers, then then second approach can be used.
2. Use different boxes
This approach allows us to use only a single register, data.R4 that can contain different types at the cost of increased complexity. The idea is the observation that the code in each input of a transaction is executed. Hence we will keep the code of a branch in its own box. The original box is modified to require that the second input has the script matching the code we desire in each branch. For efficiency, we will in fact require that the second input has the script whose hash matches the hash of the code we desire.
sigmaProp{
val thisIsFirstInput = SELF.id == INPUTS(0).id
val codeHash = blake2b256(INPUTS(1).propositionBytes)
val correctCodeInSecondInput = if (condition) {
codeHash == leftBranchBytesHash
} else {
codeHash == rightBranchBytesHash
thisIsFirstInput && correctCodeInSecondInput
The values leftBranchBytesHash and rightBranchBytesHash are hashes of the below scripts respectively:
sigmaProp{
data.R4[Long].get <= INPUTS(0).value
and
sigmaProp{
data.R4[Coll[Byte]].get != INPUTS(0).propositionBytes
Please see the working example here.
Note a few differences from the original logic:
- The main box needs to ensure that it is the first input
- The code box needs to apply the condition to the first input rather than to
SELF.
Regarding the second approach, it will probably be a good idea to use a NFT (aka “singleton token”) to ensure that the branch boxes cannot be independently spent:
sigmaProp{
data.R4[Long].get <= INPUTS(0).value &&
INPUTS(0).tokens(0)._1 == NFT
The same is done for the other branch box and the main box now also has the NFT.
