Question about difficulty calculation in Scala code
Hi, I’ve been reviewing the Scala code related to solution verification and particularly how the diffculty is calculated.
I found that for a recent block:
https://explorer.ergoplatform.com/en/blocks/5571af507c19d938e53bb8520df26fc314dd61f5395011a842f7b7aa9ab3c28d
The “nBits” are: 117968545 which is hex: 0x7080ea1
This value is passed to the method RequiredDifficulty.decodeCompactBits which look like it returns the “difficulty” which for this block is: 2267884466208768 which is hex: 0x80EA100000000.
Then in AutolykosPowScheme.scala this code divides “q” by the difficulty but “q” is not defined anywhere I can find:
204   /**
205     * Get target `b` from encoded difficulty `nBits`
206     */
207   private[mining] def getB(nBits: Long): BigInt = {
208     q / RequiredDifficulty.decodeCompactBits(nBits)
209   }
Can anyone tell me what “q” is?
I’m looking for an example of the 32 byte value “b” from AutolykosPowScheme.validate(). Thanks!
You can see its definition here. It is part of elliptic-curve parameters (namely “n”). More details in dependent lib here.
