Does anyone know how to set up 3070 ti for Ergo in HiveOS? Will it even work for mining?
It would seem your core clocks are lower than they should be, and your soc Mhz is higher than it should be.
Right now I’m stability testing and able to run the following specs for 180 Mhs @ 134W:
Core: 1300
VDDC: 875
SocMhz: 850
MemMhz: 847
Power: 134W
I run these straps for Samsung:
amdmemtweak --CL 20 --RC 37 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
And these straps for Hynix:
amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 12
I’m amazed at how you are able to get MemMHz above SocMHz - I thought it was a GPU limitation that kept Mem under Soc?
22mh/26mh Max…if oc settings türü…
Hi i,m new here but read all your comments about your rating stats.
Nanominer with NVidia 3060 Ti i got 171 MH/s.
Greets Moe
Some one mining with P104-100, how much is hashrate?
HiveOS with nanominer Question…
With an Nvidia driver 460.39 I was able to get
119 Mh/s with RTX 3060 (Fan 70, Core -300, Mem 2600, at 100W), and
172 Mh/s with RTX 3070 (Fan 70, Core -475, Mem 2600, at 130W),
but RTX 3070-TI didn’t work at all, I was getting recursive error at the boot of the OS.
After a recommendation from HiveOS team, I change the driver to 465.27, later on my own to 465.31 getting similar results as follows:
69 Mh/s with RTX 3060 (Fan 70, Core -300, Mem 2700, at 105W, 42°C), hashrate dropped by 50 Mh/s,
172 Mh/s with RTX 3070 (Fan 75, Core -475, Mem 2750, at 130W, 45°C),
175 Mh/s with RTX 3070-TI (Fan 75, Core -500, Mem 2400, at 235W, 56°C).
How do I get hashrate for RTX 3060 back to 119 Mh/s, and how to optimize RTX 3070-TI. I think the 3070-TI should get a similar hashrate to RTX-3080(or ti) since they have the same Memory speed.
Has something to do with SOC Straps. IME, memory performs best at the or close to edge of each SOC strap for 3D and ETH. Autolykos is somewhat picky. Sometimes going down 5 MHz brings you more hashrate (dwelling with this more).
With your question re: my SOC at 846 and MEM at 847 - this is really the max Mem Freq allowed by that SOC strap before switching to the next. 1MHz more and I will drop perf… so yeah…
P104-100 - 58 MH/s – info from WoolyPooly
1080TI Hashrate and Tip:
Disable P0 State
Lock Core to 1550MHz
Mem to around 5800 - 6000MHz (YMMV)
Curves for lower Power
122MHash at 150W Software.
For me if I set MemMHz to be equal to SocMHz it drops quite a bit, eg. SocMHz 847 MemMHz 747. So I have to set MemMHz to something like 843-846
Rx 5500xt oc settings?
i tried these settings on my rig and I was getting lots of stale shares a quite a few invalid shares. i did get 172MH/s on all of them though.
3060 is very picky.
MB: Asus P8Z77-WS
CPU: 3770K
OS: WIN10 Home
Miner: NBMINER
GPU: Asus TUF 3060 12GB OC
GPU Core: 1250
Memory: 1150
PL: 70%
Fan: 40C/70%
hi;
Make the frequency as in the used image and use it as a strap, you will see the miracle.
i’m not able to get my mem to 960 . otherwise i get gpu dead error. I guess 180 is the max for me :).
I have Asus Rog Strix 3070, maybe that’s why it is somewhat stable for me, but it’s not perfect. I’m also learning the OC’s, and other settings might be better.
I noticed that the acceptance can go down if, after the OC settings change I don’t reboot the system.
67W from Nanominer.
added 2 more Rx580 4GB (Total 3)
RX580 4GB - 67.4, 68.2, 68.2MH/s (Total 203.8MH/s)
Power: 67W, 94W, 92W
67W was an OEM RX580, The other 2 is Sapphire Nitro+. Seems like the OEM ones are more power efficient.
Is your vega 64 bios modded? Did you set strps and timings on amd memory tweak? If so, can you share them please? You got that hashrate just by overclocking the card?
Help me please. I have a vega 64 but can get only 110mh on 150w.
How to set the SocMHz in Windows 10?
