Thank you! Can you take a screenshot of the hashrate screen for this please?
Thanks!!
I am using HiveOS so I am not sure if the settings would be the same?
I canāt tell as I have never used itā¦
HiveOS, TeamRedMiner:
5700XT micron: 112 Mhs, core 1400, mem 940, vdd 800, power 125w
5700XT samsung: 107 Mhs, core 1400, mem 900, vdd 800, power 94w
6800: 122 Mhs, core 1400, mem 1070, vdd 800, power 123w
6700XT: 92 Mhs, core 1400, mem 1075, vdd 800, power 111w
Vega56: 190 Mhs, core 1400, mem 900, vdd 875, power 141w
HiveOS, NBMiner:
3060: 128 Mhs, core 1700, mem 3200, power limit 110w
3070: 170 Mhs, core 1600, mem 2600, power limit 120w
1660 super: 61 Mhs, core 1000, mem 1600, power limit 60w
5600XT: 81 Mhs, core 1350, mem 900, vdd 800, power 80w
Are your 3060s on risers or directly connected? I was thinking of getting some but I wasnt sure of the hashrate limit would kick in?
I have 1 of the 3060s on a riser and it gives full hashrate. The important thing is to use driver version 460.39, otherwise the hashrate limiter will kick in.
Just be careful - if you are buying new it may have the new hardware hashrate limiter, and Iām seeing conflicting reports of whether these new cards can get full hashrate.
NBMiner + GTX1050 (laptop) 27 MH/s (24hrs average)
Nvidia 1050 ti Ergo Average 1 Hour Hash Rate: 23.75 MH/s . I saw max 50mh
OK i finally figured out why I couldnāt get over 43MH on ERGO for my RX6800 Cards⦠Only on TeamRedminer can i get the hash rate up to 120⦠On Nanominer it doesnāt work for Big Navi AMD cardsā¦
Hi there, can you share your OC settings of R9_380? I“m using the same rom as you but can“t achive the same results. I“m sucked at 36 MH/s. Thanks
My OC settings for R9_380 are: core 925MHz (or 950MHz, if GPU is not stable), mem 1650MHz (elpida) or 1550MHz (hynix).
Tks a lot for the infos!!!
How much GHs should you be pushing for it to make sense to go Solo mining?
NBMiner - Dell RTX 3080 |60% pwr, core: +225, mem: + 1200| - 220MHs average. Of course fluctuates but averages 220.
Nanominer + RX580 (4GB) 67.4MH/s
Nanominer (Windows 10) + RTX3080 Aorus eGPU (466.11 driver): 63% power (201W), +240 GPU, +1350 MEM = 228.4 MH/s consistently.
TeamRedminer (Windows 10) stock settings:
MacBook Pro 16" Radeon Pro 5300M = 40 MH/s
Hades Canyon NUC Radeon RX Vega M GH = 43.5 MH/s
Windows 10 Home 64 bit
Intel(R) Celeron(R) G4900 CPU @ 3.10GHz 3.10 GHz 8 GB Ram
5x Radeon RX Vega 56 Air Boost 8G OC
No Power Page change with original FW
Switched from ETH to ERGO. Changed the OverdriveNTool setttings accoding to the teamred specs for VEGAs.
teamredminer-v0.8.3-win
OverdriveNTool (GPU_P7 has to be adapted individual for the target core clock on this power level)
GPU_P0=852;800;0
GPU_P1=991;900;0
GPU_P2=1225;850;0
GPU_P3=1138;900;0
GPU_P4=1150;900;0
GPU_P5=1202;900;0
GPU_P6=1212;905;0
GPU_P7=1269;900
Mem_P0=167;800;0
Mem_P1=500;800;0
Mem_P2=700;900;0
Mem_P3=950;900
Mem_TimingLevel=0
Fan_P0=30;45
Fan_P1=45;55
Fan_P2=50;70
Fan_P3=55;85
Fan_P4=60;100
Fan_ZeroRPM=0
Fan_Acoustic=2400
Power_Target=50
