Gathering hashrate statistics for different miners, hardware and overclocking settings.
Linux 16.04
GTX1070 memory +500 GPU +150 (boost to 1970mhz) 80-85W just 20Mhs (cant get it to use more GPU?? as PL limit is set to 110w)
GTX1060 3GB 60w - 13Mhs
GTX1080ti 160w GPU 1800mhz PL limit 160w 35Mhs
prehash is ON
GTX1080ti 160w Mem +500mhz PL limit 230w 40Mhs (linux, NVdriver 430.40)
RTX 2070 getting around 35 to 38 MH/s
Not able to use prehashes even though GPU has 8 gb. (No onboard GPU)
Are you on Windows probably?
Yes windows 10. I’ll do another test shortly with overclocking settings.
