Hi! I’m trying to create a stake delegation transaction using cardano-serialization-lib, js, and Yoroi with the CIP30 API (Cardano dApp-Wallet Web Bridge https://cips.cardano.org/cips/cip30/)
I’m using Yoroi Nightly and Testnet
Code:
delegate = async () => {
const bech32Addr = this.state.changeAddress //obtaining my payment address
const address = Address.from_bech32(bech32Addr)
const baseAddress = BaseAddress.from_address(address);
const txUnspentOutputs = await this.getTxUnspentOutputs();
const txBuilder = await this.initTransactionBuilder(); // creating transaction
txBuilder.add_inputs_from(txUnspentOutputs, 0)
const certs = Certificates.new();
const poolId = "c2b816de1ddfc9648a84c050e2dc96af0bc1ccbfb2c4cc2b050c78d4"
const poolKeyHash = Ed25519KeyHash.from_bytes(Buffer.from(poolId, 'hex'));
//Adding StakeDelegation Certificate
certs.add(
Certificate.new_stake_delegation(
StakeDelegation.new(
baseAddress.stake_cred(),
poolKeyHash
txBuilder.set_certs(certs)
txBuilder.add_change_if_needed(address)
const txBody = txBuilder.build();
const transactionWitnessSet = TransactionWitnessSet.new();
const tx = Transaction.new(
txBody,
TransactionWitnessSet.from_bytes(transactionWitnessSet.to_bytes())
// "this.API" is the Yoroi API created using "window.cardano[walletKey].enable()"
let txVkeyWitnesses = await this.API.signTx(Buffer.from(tx.to_bytes(), "utf8").toString("hex"), true);
txVkeyWitnesses = TransactionWitnessSet.from_bytes(Buffer.from(txVkeyWitnesses, "hex"));
transactionWitnessSet.set_vkeys(txVkeyWitnesses.vkeys());
const signedTx = Transaction.new(
tx.body(),
const submittedTxHash = await this.API.submitTx(Buffer.from(signedTx.to_bytes(), "utf8").toString("hex"));
This exact code is working correctly with the following Wallets (also using CIP30):
- Nami
- Flint
- CCVault / Eternl
- Typhon
- Nufi
The only Wallet that doesn’t work is Yoroi.
This is the error I’m getting:
"transaction submit error ShelleyTxValidationError ShelleyBasedEraBabbage (ApplyTxError [UtxowFailure (FromAlonzoUtxowFail (WrappedShelleyEraFailure (MissingVKeyWitnessesUTXOW (WitHashes (fromList [KeyHash "bdd5302aa402af3018f558b9eef255751633abc32c7352d9eb1d2f37"])))))])"
Maybe I’m wrong but I think Yoroi is not signing the StakeDelegation certificate.
I also tried adding the StakeRegistration Certificate and the result is the same.
I’m able to create regular transactions with Yoroi (only sending ADA), I just can’t do transactions related to Staking.
If you are wondering why I want to do this and not use the Yoroi UI is because I want to add metadata to the transaction and also so the users can delegate directly from my website.
